I am trying to find the flow chart for the findme program by analyzing the source code files.
I was wondering what does "__enable_irq() " do in the source code main_cm4.c file?
Here, I don't see any declaration for interrupts
* File Name: main_cm4.c
* Version 1.10
* Description:
* This is the source code CM4 core for the BLE project (for dual cores MPN).
* Hardware Dependency:
* CY8CKIT-062 PSoC6 BLE Pioneer Kit
* CY8CPROTO-063-BLE PSoC 6 BLE Prototyping Kit
* Copyright (2018), Cypress Semiconductor Corporation.
* This software is owned by Cypress Semiconductor Corporation (Cypress) and is
* protected by and subject to worldwide patent protection (United States and
* foreign), United States copyright laws and international treaty provisions.
* Cypress hereby grants to licensee a personal, non-exclusive, non-transferable
* license to copy, use, modify, create derivative works of, and compile the
* Cypress Source Code and derivative works for the sole purpose of creating
* custom software in support of licensee product to be used only in conjunction
* with a Cypress integrated circuit as specified in the applicable agreement.
* Any reproduction, modification, translation, compilation, or representation of
* this software except as specified above is prohibited without the express
* written permission of Cypress.
* Disclaimer: CYPRESS MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH
* REGARD TO THIS MATERIAL, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
* Cypress reserves the right to make changes without further notice to the
* materials described herein. Cypress does not assume any liability arising out
* of the application or use of any product or circuit described herein. Cypress
* does not authorize its products for use as critical components in life-support
* systems where a malfunction or failure may reasonably be expected to result in
* significant injury to the user. The inclusion of Cypress' product in a life-
* support systems application implies that the manufacturer assumes all risk of
* such use and in doing so indemnifies Cypress against all charges. Use may be
* limited by and subject to the applicable Cypress software license agreement.
#include "common.h"
* Function Name: main()
* Summary:
* Main function for the project.
int main()
/* Unfreeze IO after Hibernate */
if(Cy_SysPm_IoIsFrozen())
Cy_SysPm_IoUnfreeze();
/* Enable global interrupts */
__enable_irq();
#if(CY_BLE_CONFIG_HOST_CORE == CY_BLE_CORE_CORTEX_M4)
/* Run Host main */
HostMain();
#else
for(;;)
/* To achieve low power */
Cy_SysPm_DeepSleep(CY_SYSPM_WAIT_FOR_INTERRUPT);
#endif /* (CY_BLE_CONFIG_HOST_CORE == CY_BLE_CORE_CORTEX_M4) */
/* [] END OF FILE */
Indeed, you don't see any declaration for interrupts. But, bluetooth radio subsystem use own interrupt handler.
You can see it on Find Me Project , Design Wide Resources → Interrupts.
Out of device reset, all interrupts are disabled and interrupt priorities are set to zero.
More information on AN217666 - PSoC 6 MCU Interrupts and AN210781 - Getting Started with PSoC 6 MCU with Bluetooth Low Energy (BLE) Connectivity
Thank you Liviu Dogargu !! the resource shares is of great help!! thank you so much.
Liviu Dogaru,
I was wondering if there is a detailed similar file for Psoc6 BLE prototyping kit with device CYBLE-416045-02.?
if so can you please share it?
Hi chaithanyas_3700256,
you can find information about Psoc6 BLE prototyping kit here.
Liviu
