03:30 PM
Jan 12, 2016
03:30 PM
In PSOC Creator, is it possible to have multiple projects that share a "top design". For example, you come up with a "hardware" design -- schematics, pin assignments, clocks, etc. You want to use this same design in two projects -- same "hardware", same generated software but with different user specified software, for example, a different main, etc.
Clearly, you can just copy a project and get two projects with the same design but this gives you two separate designs to maintain.
Any ideas?
03:46 AM
Jan 13, 2016
03:46 AM
Just hard-link the schematic files (using junction.exe).
