wwfeldman
First like received Welcome!
in  PSoC creator, is there a way to save the user input files, such as main.c, topdesign, pins, that have the user input, and not save generated files?
do the user input file names indicate that they are user input files?
do the generated file names indicate that they are generated?
NoriakiT_91
If you want to do a revision control, There is a nice KBA.
Revision Control for PSoC® Creator™ Projects - KBA86358
There are some discussions related to this KBA on the community.
Noriaki
Rakshith
Hi LaAd_4048266​,
The files that are generated by PSoC Creator will be stored in a separate folder called Generated Source. Can you please let me know the reason for your requirement? It will help me provide a more appropriate solution or a workaround. Also, can you let me know the device that you are using?
You can also refer to Section 4.2 - Locating and Identifying Source Files in this application note to know about the file structure in PSoC Creator - AN219434 - Importing PSoC Creator Code into an IDE for a PSoC 6 Project
Please let me know if this helps.
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
NoriakiT_91
Noriaki
wwfeldman
Hello Rakshith M B
my goal is to be able to use two or more different computers,
one at my office, and one at home.
i need the user input files, the generated files can always be re-generated
i am developing using 5LP Kit-059.
wwfeldman
PS thank you Noriaki
i have downloaded the ap-note and will read it
