at sudden, whenever some code write, 'assertion failed' happened.
I read some topic about this problem, and cypress employee said 'solve it after 3.2'
but No.
what can i do?
PS. some solution that write code 'assertion' read , but my problem is not concerned about that.
Bob_Marlowe
Level 10
Level 10
As you can see there are no complains about errors in the clang-library in the forum since Creator 3.3.
I would suggest you to de-install creator, download and re-install the latest version from Cypress website. I also suggest to use the default installation path and not drive 😧 (just to make sure)
Bob
Bob_Marlowe
Level 10
Level 10
Bob
I tried to do way that you suggest, but after installing again, this problem happened again.
Bob_Marlowe
Level 10
Level 10
Do you have a chance to use a different PC? Are you using a standard windows? Network??
Bob
absolutely, I use a standard windows 7, and also use certified network.
I thought that this problem is caused by internal system conflict. whenever I shut down the window,
some problem happen caused by psoc_creator. (index error?)
after re installing windows, I will reply.
Bob_Marlowe
Level 10
Level 10
When all fails, get in contact with Cypress directly:
At top of this page select "Design Support -> Create a Support Case" and describe your problem.
Leave phone number, timezone and time to call you. Cypress can help using remote control of your PC.
Bob
it also did, so some employee said
'I am routing this case to one of our engineers supporting BLE products to assist you further with this query.'
thanks for your help
