Hi, after the update to PSOC Creator 3.1 SP3 when i build a project (even a void project) the compiler raise an error: "prj.M0120:Build Error: Existing file." (in italian "File esistente"). But what means? where is the error? There aren't other informations.
Thank you!
Consider posting your project, makes life easier to troubleshoot.
“File” Creator
“Create Workspace Bundle”
Regards, Dana.
here there is the zipped project
Ehm, i can't upload. error during the upload. 😕
Welcome in the forum!
Consider to use a different browser, this mostly works. Are any of the files on a network drive? Which OS?
Bob
Project compiled without errors or warnings on a win7 machine.
Bob
even downloaded example projects give the same error during building stage 😞
Try to run Creator with admin rights, probably you do not have write / delete access rights to a directory.
Which OS are you running Creator on (WHICH windows)?
Bob
I'm running PSOC Creator on Win7 (currently updated).
I tried to run psoc creator in admin mode without positive results.
Now I'm going to run it from wine in linux...
Probably Cypress Programmer will not run under wine, think I've seen something like that.
Everybody here runs Creator successfully under windows from XP to 8.1, so it must be something in your installation going wrong. I would suggest you to create a MyCase: At top of this page "Support & Community -> Technical Support -> Create a MyCase" Leave as much information as possible and your phone number.
Bob
ok thank you! 🙂
ok, I've solved deleting removing the suite and the files in Appdata, then reinstalling all the programs. 🙂
Good to hear that! Welcome in the fascinating world of PSoCs!
Bob
hi ... we are making a pulse oxymeter using psoc 4200m .In the UART part we are getting an error as
prj.M0120 :build error .Undefined reference to 'UART_PutChar'.
HERE UART is the name of the sw_tx_uart we are using.
Have a look into the generated .h -file and search for "putchar". This is usually just a typo.
If not, can you post your complete project, so that we all can have a look at all of your settings? To do so, use
When you cannot lay open your code to the public, create a support case (at top of this page -> Design Support -> Create a Support Case" and get in contact with Cypress directly. They will keep your code confidential.
Bob
hi,,
can you please tell us how to display values on uart...
we are getting garbage values right now..
i have uploaded the project in my previous post...
We have November and I do not see any actual workspace you uploaded.
Are you using a CY8CKit-044?
Bob
yes we are using Psoc 4200M(CY8CKit-044)
