Iam using psoc creator 4.1 .I want to view the value of u_n8Zone by using breakpoint.But compiler show u_n8Zone is "optimised out"> .what is the reason for this.How do i view the value of u_n8Zone.
Here is the code
#include "project.h"
#include "SmartCardI2C.h"
#define true 1;
#define false 0;
int m;
int ICCARD_STATUS_RECHARGE_SUCCESS;
int ICCARD_STATUS_WRITE_FAIL;
int ICCARD_STATUS_USED_CARD;
int ICCARD_STATUS_READ_ERROR;
int ICCARD_STATUS_CARD_NOT_PRESENT;
int ICCARD_VALUE_SERVICE_USER;
int ICCARD_STATUS_WRITE_SUCCES;
int ICCARD_VALUE_FACTORY_USER;
int ICCARD_STATUS_FACTORY_CARD;
int ICCARD_STATUS_SERVICE_CARD;
int ICCARD_VALUE_NORMAL_USER;
int ICCARD_STATUS_NORMAL_CARD;
int SMART_CARD_POWER_PIN;
int GPIO_DIRECTION_OUT;
int SMART_CARD_SENSE_PIN;
int GPIO_DIRECTION_IN;
int SMART_CARD_RESET_PIN;
bool GetULongValueFromCard(u_int8_t u_n8ZoneNo,u_int8_t u_n8ZoneAddress,u_int32_t *ptr_u_n32Value);
bool ReadCardUserZone(u_int8_t u_n8Zone,int nAddress,u_int8_t *ptr_u_n8Data,int nNoofBytes);
int SendBytesToCard(int nNumber,u_int8_t *ptr_u_n8Data);
u_int8_t GetRechargeValue(u_int32_t *ptr_u_n32RechargeValue);
bool GetByteFromCard(u_int8_t u_n8ZoneNot ,u_int8_t u_n8ZoneAddress,u_int8_t *ptr_u_n8ByteAddress);
bool WriteULongValuetoCard(u_int8_t u_n8Zone,u_int8_t u_n8ZoneAddress,u_int32_t u_n32ValueToLoad);
void ReadBytesFromCard(int nNumber, u_int8_t *ptr_u_n8Data);
int WriteCardUserZone(u_int8_t u_n8Zone,int nAddress,u_int8_t *ptr_u_n8Data,int nNoofBytes);
int InitSmartCard();
void resetGetPinStatus();
bool GetCardPresentStatus();
u_int32_t *ptr_u_n32Value;
CyGlobalIntEnable;
InitSmartCard();
if(1==GetCardPresentStatus())
GetULongValueFromCard(10,1, ptr_u_n32Value);
return 0;
//SmartCard()
//GPIO Sense()
//GPIO Sense;
//GPIO Power;
int InitSmartCard()
int nI;
InitializeI2C();
cardrst_Write(1);
//resetSetPinStatus();
/*if(I2C_FAIL == InitializeI2C())
return SMART_CARD_FAIL;
if(GPIO_FAIL == SetPinDirection(GPIO_DIRECTION_OUT,SMART_CARD_POWER_PIN))
return SMART_CARD_PASS;*/
//WriteByteToCard(10,0,ICCARD_VALUE_FACTORY_USER);
nI=WriteULongValuetoCard(10,1,100);
//SetcardasServiceCard();
return 0;
bool bStat;
bStat = GetULongValueFromCard(10,1,ptr_u_n32RechargeValue);
if(1 == bStat)
if((*ptr_u_n32RechargeValue)!=0)
if(1 == WriteULongValuetoCard(10,1,0))
return ICCARD_STATUS_RECHARGE_SUCCESS;
else
return ICCARD_STATUS_WRITE_FAIL;
else
return ICCARD_STATUS_USED_CARD;
else
return ICCARD_STATUS_READ_ERROR;
else
return ICCARD_STATUS_CARD_NOT_PRESENT;
if(1==ReadCardUserZone(u_n8ZoneNo,u_n8ZoneAddress,(u_int8_t*)(ptr_u_n32Value),4))
return true;
return false;
return WriteCardUserZone(u_n8Zone,u_n8ZoneAddress,(u_int8_t*)(&u_n32ValueToLoad),4);
bool GetByteFromCard(u_int8_t u_n8ZoneNo,u_int8_t u_n8ZoneAddress,u_int8_t *ptr_u_n8ByteAddress)
return ReadCardUserZone(u_n8ZoneNo,u_n8ZoneAddress,ptr_u_n8ByteAddress,1);
bool WriteByteToCard(u_int8_t u_n8ZoneNo,u_int8_t u_n8ZoneAddress,u_int8_t u_n8Value)
return WriteCardUserZone(u_n8ZoneNo,u_n8ZoneAddress,&u_n8Value,1);
u_int8_t SetCardAsServiceCard()
//if(true == GetByteFromCard(10,0,&u_n8CardType))
if(1 == WriteByteToCard(10,0,ICCARD_VALUE_SERVICE_USER))
return 1;//ICCARD_STATUS_WRITE_SUCCES;
else
return 2;// ICCARD_STATUS_WRITE_FAIL;
else
return 3;// ICCARD_STATUS_CARD_NOT_PRESENT;
u_int8_t CheckCardType()
u_int8_t u_n8CardType;
if(1 == GetByteFromCard(10,0,&u_n8CardType))
if(u_n8CardType == ICCARD_VALUE_FACTORY_USER)
return ICCARD_STATUS_FACTORY_CARD;
else if(u_n8CardType == ICCARD_VALUE_SERVICE_USER)
return ICCARD_STATUS_SERVICE_CARD;
else if(u_n8CardType == ICCARD_VALUE_NORMAL_USER)
return ICCARD_STATUS_NORMAL_CARD;
else
else
else
u_int8_t u_n8SendData[20];
int nI=0;
cardpower_Write(1);// SMART_CARD_POWER_ENABLE
CyDelay(200);
u_n8SendData[nI++] = 0xB4;
u_n8SendData[nI++] = 0x03;
//User Zone 0- read 8 bytes from here initially.
u_n8SendData[nI++] = u_n8Zone;
u_n8SendData[nI] = 0;
nI = SendBytesToCard(4,u_n8SendData);
i2cstop();
if(nI ==1)
//read user config 0
nI = 0;
//Read Config Zone
u_n8SendData[nI++] = 0xB2;
u_n8SendData[nI++] = 0x00;
//User Zone 0-
u_n8SendData[nI++] = nAddress;
u_n8SendData[nI] = nNoofBytes;
if(nI == 1)////(nI==SMART_CARD_PASS )
ReadBytesFromCard(nNoofBytes,ptr_u_n8Data);
cardpower_Write(0);//SMART_CARD_POWER_DISABLE
return 1;
u_int8_t u_n8Senddata[200];
int nI=0,nJ;
cardpower_Write(0);//SMART_CARD_POWER_ENABLE
CyDelay(200);
//i = 0;
//setting user zone
u_n8Senddata[nI++] = 0xB4;
u_n8Senddata[nI++] = 0x03;
u_n8Senddata[nI++] = u_n8Zone;
u_n8Senddata[nI] = 0;
nI= SendBytesToCard(4,u_n8Senddata);
i2cstop();
if(nI ==1)//(nI==SMART_CARD_PASS )
//Write user zone
nI = 0;
//Write User zone
u_n8Senddata[nI++] = 0xB0;
u_n8Senddata[nI++] = 0x00;
u_n8Senddata[nI++] = nAddress;
u_n8Senddata[nI++] = nNoofBytes;
for(nJ = 0;nJ < nNoofBytes;nJ++)
u_n8Senddata[nI++] = ptr_u_n8Data[nJ];
nI = SendBytesToCard(nNoofBytes+4,u_n8Senddata);
i2cstop();
//power down
CyDelay(200);
cardpower_Write(1);//SMART_CARD_POWER_DISABLE
return 1;
int nI=0;
while(nNumber--)
ptr_u_n8Data[nI]=i2cgetbyte();
nI++;
if(nNumber > 0)
i2csendack();
i2cstop();
int nI=0;
int nRetry = 0;
int var;
i2cstart();
while(nNumber--)
var =i2csendbyte(ptr_u_n8Data[nI]);
if(!i2cgetack())
i2cstart();
nNumber++;
nRetry++;
if(nRetry > 5)
return 0;
else
nI++;
return 1; // SMART_CARD_PASS
cardrst_Read();
if(0 == cardsense_Read())
return true;
else
return false;
please help me to slove this problem.
Hi Jaseela,
You can try to set optimization level as none(I'm not sure if it can work...)
Or you can try to use the keyword 'volatile' when define u_n8Zone, then u_n8Zone won't be optimised out.
Ryan
Hi Jaseela,
Ryan
Thank u. it work
