ezbe_290006
10 replies posted 10 sign-ins 5 replies posted
i am trying to create a usb to uart spliter but can i create 5 virtual ports , from the usb?
thanks.
RodolfoGL
250 solutions authored 250 sign-ins 5 comments on KBA
Probably you can, but you might run out of Endpoints, so you would need to create some custom driver.
If you need only 4 UARTs, you can actually use the CDC Device Class to do this. Each physical UART would be linked to a pair of endpoints (OUT and IN endpoints).
RodolfoGL
