Hi all, I have a code of my project, think so its correct.
But while I'm building it I'm getting the o/p with errors as:-
Performing Project Clean...
done
Starting MAKE...
creating project.mk
lib/csa_emc.asm
!E CSA_EMC.inc(19): no such mnemonic 'Wizard_was_not_called_after_place_rename_configuration_change_or_update_Open_Chip_Editor_open_Wizard_press_OK_button_and_generate_project'
make: *** [lib/obj/csa_emc.o] Error 1
make: *** Deleting file `lib/obj/csa_emc.o'
What does this mean or what do it relate to?
Waiting for help.
Thanks & Regards-
Amit
Bob_Marlowe
Level 10
Level 10
Errormessage says that you have to open the wizard for your CapSense module to have some renamings done. Do accordingly and the message disapears.
Bob
Thanks Bob, I tried your suggestion & it worked fine for the first 8 buttons. Guide me on implementation of the 2nd byte of the sensor, keeping 1st byte alive.
If you are able to guide me today, it will be fine. I'm going on the vacations for the Diwali Festival(of lights) for the next six day's.
Hope we will get back quickly. Happy Diwali.
Thanks & Regards-
Amit
Bob_Marlowe
Level 10
Level 10
Fine that the compiling-error is solved. The other part of your question was asked and answered here www.cypress.com/
Bob
