I have had PSoC Creator 3.2 working on my PC previously, and I have 3.3 working on another PC.
However, I recently re-installed Windows Vista on this PC, and then installed PSoC Creator with Admin rights. The problem is now, I get this error whenever I try to compile a PSoC4 project:
arm-none-eabi-gcc.exe: error: CreateProcess: No such file or directory
This happens with *all* projects using the arm compiler, including projects which were previously working, and also all example projects.
I have tried doing a repair install, and a full uninstall and re-install. But that didn't make any difference. I have also tried some of the advice I've seen on the other two threads regarding this problem: Adding gcc.exe's path to the Windows Path, etc. But nothing has helped.
Has anyone actually solved this problem?
Hugo
Some leftovers from a de-installation probably. Cypress has got a script to clear the registry, so create a Support Case (at top of this page click on "Design Support" and select "Create a Support Case"
Bob
