download creator and wont compile on 2 computes
invisyguard
I have downloaded creator 4.4 on 2 computers and both have same error wont compile no matter whats in the project incuding nothing.
1 comput erwindows 10 64 bot the other computer windows 7 32 bit
unsing Psoc6 63 dev kit
Dom,
The PDL is the Peripheral Device Library.  It is used by the PSoC6 projects.
It appears something is wrong with the path declaration for the PDL.
Please follow these steps:
  • Select the menu "Tools/Options..."
  • Include a screenshot of the "Options" window that pops up.  (See example below.)
The PDL v3 line is the one we are trying to diagnose/fix.
Len
Len_CONSULTRON
Level 9
Level 9
invisyguard,
It appears that the error is that the PDL path is invalid.  When you installed 4.4, did it complain that it couldn't install certain items?
Can you share your project?  This might help to locate the problem.
Len
invisyguard
Hi Len
I dont know what PDl path is
The installations did not give any error when installing they just asked normal install and I ticked yes.
The project does not matter it has same errors.
Projects tried
PSCO6 101 lesssion 2
Preloaded program may selected
Clear program as example listed with only the PSCO6 63 part selected
Dom
Dom,
Len
invisyguard
Hi Len
Thank you works now but my PLD is 3.13, do you have a beta version as I downloaed the lastest version from cypress?
Dom,
I found 3.14 using "Cypress Update Manager".
Len
Hello @invisyguard ,
You can download the latest PDL 3.1.4 version from here as well manually if required: https://www.cypress.com/design-guides/peripheral-driver-library-pdl-psoc-creator
Dheeraj
