- Email to a Friend
hello
used PSoc 4.2.
i defined a uint8 XXX variable.
in another file, by mistake, this variable defined as: extern uint32 XXX;
there was no warning. in MAP file the XXX is located as 1 byte. but we have a memory override of another variable that located in the near address.
please advice if there is a way to check such cases automatically (by compiler....)
thanks in advance
Alexander
PSoC Creator & Designer Software
- extern var
- Email to a Friend
You got no warning due to the implicit type conversion of XXX and it's a secure type conversion (uint8 -> uint32). It's a legit and designed manner so no warning is given by default.
In your case, it's equivalent to:
uint8 XXX = 1;
uint32 YYY = 2222222;
*(uint32*)&XXX = YYY;
The above example gives no warning, too. But it violates the allocation of XXX and memory overlapping happens.
This behavior is recognized as user-responsible so you can't expect an auto-check by the build system.
- Email to a Friend
uint8 XXX = 1;
- Email to a Friend
thank you for clarification
- Email to a Friend
I also tried your case, and reproduced the same problem.
IMHO, Linker has the only chance to detect this problem and (I think that) should flag a warning.
But as far as I tried, I could not find a linker flag to warn linking the variable with different size(s).
Since GCC has millions of runtime arguments, may be there is/are some flag to take care of this,
but I could not afford to search all. (I'm sorry)
Although I understand that this is not what you expected,
I tried to have a header file which defines all "external".
Then the compiler could report error and stopped.
In the followings, if I uncomment the definition of
extern uint32_t XXX ;
in sub.h, the compiler can generate error.
If I keep it commented, the project compiles OK,
but as you wrote, crashes when the line of assignment to XXX is executed. >_<
sub.h
#ifndef _SUB_H_
#define _SUB_H_
#include "project.h"
// extern uint32_t XXX ;
void sub_function(int32_t a) ;
#endif
sub.c
#include "sub.h"
void sub_function(int32_t val)
XXX = val ;
main.c
#include "stdio.h"
#include "sub.h"
uint8_t WWW = 12 ;
uint8_t XXX = 0xCD ;
uint8_t YYY = 34 ;
uint8_t ZZZ = 56 ;
char str[128] ;
void print_values(void)
snprintf(str, 128, "%d, %d, %d, %d\n\r",
WWW, XXX, YYY, ZZZ) ;
UART_UartPutString(str) ;
uint32_t i ;
CyGlobalIntEnable; /* Enable global interrupts. */
UART_Start() ;
UART_UartPutString("\x1b[2J\x1b[;H") ;
print_values() ;
for(;;)
for (i = 0 ; i < 0x100 ; i++ ) {
sub_function(i) ;
print_values() ;
CyDelay(500) ;
moto
- Email to a Friend
thank you
