- Email to a Friend
I'm a newbie to Cypress, I'm picking up where other people left off...
When using 4.x cyelftool, what causes this message to occur? This message does not occur using the 3.3 version of the tool on the same input file.
- Email to a Friend
Hi Jim,
Could you share with us some log of the error?
Ryan
- Email to a Friend
Generated_Source\PSoC4 -Wl,-Map,.\CortexM0\ARM_GCC_541\Release/second_stage_boot_loader.map -T .\cm0gcc.ld -specs=nano.specs -Wl,--gc-sections -g -ffunction-sections -Os -ffat-lto-objects -Wl,--end-group
cyelftool.exe -C C:\svn\Transformer\trunk\src\connectivitynode\Source\BleReference\second_stage_boot_loader.cydsn\CortexM0\ARM_GCC_541\Release\second_stage_boot_loader.elf --flash_row_size 256 --flash_size 262144 --flash_offset 0x00000000
No ELF section .cychecksum found, creating one
Application checksum calculated and stored in ELF section .cychecksum
Checksum calculated and stored in ELF section .cymeta
Failed to generate C:\svn\Transformer\trunk\src\connectivitynode\Source\BleReference\second_stage_boot_loader.cydsn\CortexM0\ARM_GCC_541\Release\second_stage_boot_loader.hex: Flash address outside hex file range
The command 'cyelftool.exe' failed with exit code '1'.
--------------- Build Failed: 12/17/2018 07:41:34 ---------------
From what I understand, this particular image only creates a RAM image that we subsequently use for our own purposes. The 3.3 PSoC creator gave no errors, only the 4.x is giving errors.
- Email to a Friend
Follow-on question: is there a way to SKIP cyelftool for a given project ? This is under Windows, PSoC Creator 4.x
- Email to a Friend
I haven't met this issue.
But sometimes this kind of issue caused by some invalid configuration of tool chains.
Could you share the full project, so that we can try reproducing the error and try to find workaround?
Ryan
