Hi all,
I was wondering if anyone knows what's going on, if this is normal operation or what's wrong but I have been experiencing my creator hanging like clock work. Whenever I had updated the .cysch file, regardless of the amount, it can be rerouting a wire or adding a pin/component. It always gets stuck on "Clean Temporary File ..." for several minutes, and then goes ahead and finishes the job.
If I have created a brand new project, I can edit the .cysch file a few times without this happening.
I can edit the c code portion of the psoc just fine and it generates the files in a flash as normal.
Is there any way I can fix this? its really annoying and tends to make an hour long programming session turn into 2+ hrs.
thanks in advance,
scarlson
I have a similar problem for the Creator 3.3 for Win XPx32 only.
Program hangs during text editing.
For Win7x32 and Win7x64 - no problem.
I have no solution - I try not to use XP
Avoid using files on a network
Bob
I'm not using files on a network, I'm using it on my local machine, what's frustrating is it used to work fine when I used it last year for a different project but now it's been like this forever.. and I posted a question about this months ago but got no response so I'm re-posting because It's becoming a huge factor in production time.
I am using windows 7 professional, with creator 3.2. Is there anyway I could see what creator is doing that is taking so long so I can file something with cypress or pursue to fix this?
Thanks in advance,
scarlson
Latest version of Creator is 3.3. I am running Creator on the same windows version a you have got. I would suggest you to create a support case and get help from Cypress directly. (Top of this page "Design Support")
Bob
scarlson, did this ever get resolved?
Let me know here or email me at psoc_creator_feedback@cypress.com.
See this thread as well. http://www.cypress.com/forum/psoc-creator-software/psoc-creator-33-slow
