i am using psoc creator 3.3 service pack 2.i want part cy8c4126axi-443 (44 pin tqfp) this part is showing on website but not showing in creator device selector page.
so i try to download creator 4.
i download PSoCCreatorSetup.exe of 684,705kb
when i run it it install all things and after that at end its display with run update manager checkbox and finish button with out any error.as soon as i click finish button another window open like installer and started download lots of thing from internet(i think its creator 4 update pack).this is also successfully installed.but when i check in start Manu or in cypress folder no creator 4 is installed only old 3.3 is showing......
i repeat this step 3 times but same issue its frustrating........please any one can help????
rola_264706
Level 8
Level 8
What OS are you using?  Look in Program Files X86 and the Cypress and the Psoc Creator should be there.  Please tell me what you have in these files.
only two folder
1-Updater
2-updates
i think psoc creator 4 folder missing..
i am using windows 7.......
AnkitaS_51
Have you tried downloading the PSoC Creator setup from this link-
http://www.cypress.com/products/psoc-creator-integrated-design-environment-ide
yes its 669mb exe file downloaded from same link
AnkitaS_51
Are you using any AntiVirus on your system,then please disable it
already try by disabling essential but did not work..
AnkitaS_51
Can you try the steps as mentioned in this document attached and tell us about your observation
