ChAr_4803626
Hi, i have gotten some problems when i try to start on my psoc creator 4.4, because it doesn't begin and windows show up a compatibility problem, i have been using psoc creator since july with out problems, but on the last week appeare the problem.
I appreciate any help or advice, thanks.
DheerajK_81
Windows updates sometimes might cause such problems. Please do the following:
(1) Navigate to the path: C:\Program Files (x86)\Cypress\PSoC Creator\4.4\PSoC Creator\bin
(2) Right-click on psoc_creator.exe > Properties
(3) Go to Compatibility tab
(4) Click Run compatibility troubleshooter > Try recommended settings > Test the program. Check if it works.
Dheeraj
DheerajK_81
Dheeraj
