Im writting a software that need to be released for more then 80 devices, all with the same aoftware but another ID, the usb pid is effected.
I have a file name config.h and a define that define the ID, the usb library generated by psoc creator (generated.once and been modified). I wish that the file compiled the .hex and all others will be with a name like "compiled_id_" DEV_ID ".HEX"
Is it possible?
PSoC Creator & Designer Software
Hello.
You might want to use scripts to compile your project where the script changes the DEV_ID.
See the following thread for this.
Solved: Compile project from command line - Infineon Developer Community
Good luck with your project.
Hello.
NatiUnger,
BiBi is correct. You can create batch scripts that can name the output HEX files the names you desire.
Another possible method is to use the "Build Settings.../ARMxxx/User Commands/" to place CLI commands in either "Pre Build" and/or "Post Build" arguments. I have used "Post Build" to move the HEX file generated to a different directory.
