I searched the forum and haven't seen mention of this ....
While cleaning up a lot of components and projects in preparation for release of a new component library I was using a Project Datasheet generated for a project to setup a clean room new project.
Imagine my chagrin when setting the pin assignments for D-/D+ to see the pin numbers and descriptions apparently reversed in the project datasheet. This was on Creator 3.1 SP1, so I updated to SP2 and re-tested. Same results.
Attached is a PDF with some screen snips from the PDFs that show where the Project Datasheet have D+/D- reversed vs. the Part Datasheet and the CYDRW for the working project (which are correct and work).
No penalty. I don't think CYDRW will let you reverse them but when you tell someone to setup all the pins to match the Project Datasheet you have provided it will leave a bit of confusion.
-Ed
Consider posting a CASE on this to get this rectified.
To create a technical or issue case at Cypress -
“Support”
“Technical Support”
“Create a Case”
You have to be registered on Cypress web site first.
Regards, Dana.
Thanks for pointing out.
I will ensure to addres this to software team and get it fixed in the next release of Creator.
Keerthi
