Hi I'm I want to read the analogue signal using the CMOP and use the CM4 core to the control code, to save the ADC conversion time in my work. is there a simple way to transfer the integer value from core to core?
please consider that I'm a power engineer and my programming skills are not soo good
thanks
ibraim
PSoC Creator & Designer Software
Hi @iabdelsalam ,
I have attached here a sample program (Developed for 062-BLE-Pioneer Kit) where I have demonstrated using the CM0+ CPU to initialize the ADC and start data acquisition from the same. This data is then sent to the CM4 CPU using IPC Pipes and the CM4 displays the same in the UART terminal.
So data acquisition is done by CM0+ and the processing is done by CM4.
Please go through the same and let me know if the same works for you.
Warm Regards
Alen
