AnEy_1336741
10 replies posted 5 replies posted 5 questions asked
I tried to wrap a predefined interrupt handler by use of the --wrap option of the GNU linker. Result is "option not known" or something like that. Seems as --wrap is not supported in the PSoC-version of the linker? Or did I something wrong. I filled in the Build settings of the linker a command line entry: --wrap=CySysWdtIsr         I tried several syntax variants as I found them in the www. Nothing worked.
Any idea?
Bob_Marlowe
Level 10
Level 10
Does this discussion help you?
Bob
Bob_Marlowe
Level 10
Level 10
Bob
Thank you, but: Not really, since I just cannot go far enough to find if it's doing the right. The linker doesn't understand my --wrap=CySysWdtIsr
It seems to be a command line topic, as I get this "command not known" error from the linker.
Andreas
Bob_Marlowe
Level 10
Level 10
There is no "wrap" option for GCC 4.9 mentioned in the manual, look here.
Bob
I found it in the documents section of Creator 3.3: Help -> Documentation -> GCC-Documentation -> GNU Linker. On page 33 ...
