So I have this main.c program that was made long ago (by another employee). It was made for CY8C4245PVI-482. I'm trying to understand the program, but there are a bunch of library functions. I don't know where to find documentation on them. For example
int status = UART_DMX_ReadRxStatus();
I searched for "UART_DMX_ReadRxStatus" online and there is one result. Some documentation would be immensely helpful! Is ther any PDFs or links to relevant documentation available? (The PSoC Creator User Guide does not help.)
PSoC Creator & Designer Software
Hello.
Open the project in Creator and display the schematic.
Double click on the component with label UART_DMX and a configuration window will open.
At the bottom left corner of this configuration window, you'll see a tab for Datasheet.
Click on Datasheet and do a word search for ReadRXStatus.
You can view any of the component datasheets using this method.
The Miniprog 3 manual is available at Cypress website.
https://www.cypress.com/file/44091/download
I know nothing about DMX, but you can search DMX at Cypress and they have app notes on the topic.
Good luck with your project.
Hello.
Hi @adamelli ,
Please refer to PDL API reference manual to understand more about library function
Could you please share the exact code example which you are using?
Krupashankar
