some components like FlipFlops don't have a dedicated Verilog file. It seems that those files are generated by the corresponding customizer.
Does anyone know where those files are stored after the build process? I couldn't locate them inside the project directory.
I didn't noticed that the FF haven't any Verilog files, maybe you can find information on the Verilog file that's generated from the project schematic, it's located on the same directory as the .hex, .elf files.
Hi Carlos,
you're right, I've searched for the components .v file, that's the reason why I didn't found anything.
I found the project .v file in the codegentemp directory. It seems that this file collects all relevant verilog data.
Thank you.
