PSoC Creator User Guide states that the following functions are affected by the settings in the operating conditions about pin voltage.
- The USB_Start function
- The ADC_CountsTo_Volts() API
- The SAR_ADC Component
- The SC block Components
- The VDAC8
- Static Timing Analysis
The customer and I want to know all the other functions affected.
What is it?
Inoue
Hello Inoue-san,
It is always a good practice to set the actual pin voltage levels in the settings tab of PSoC creator. Because there are certain APIs which uses the voltage setting value in the settings tab. Apart from the mentioned, few APIs related to CaPSense also uses the voltage levels in the GPIO settings.
Thanks and regards
Ganesh
Hello Inoue-san,
Thanks and regards
Ganesh
