EthanHQaQ
First question asked Welcome!
Recently I tried to use StripLights component from WS281xLib on the CY8C4146AXI-S455, while I met the error seen as attached.
Is that because the CY8C41 family doesn't support the components? It was working when I changed the device to CY8C4247AZI-L445.
Appreciate that someone can tell me the reason.
And suggest the better solution to light the strip LEDs on the CY8C4146AXI-S455.
Ethan
BiBi_1928986
Level 7
Level 7
First comment on blog 500 replies posted 250 replies posted
Hello.
You are correct.  PSoC 4146 is missing the UDB component.  4146 won't support the library component WS281xLib.
Here's a link where someone ported an Arduino implementation over to PSoC 4, using GPIO's.
https://www.hackster.io/juanespj/psoc-neopixel-easy-lightweight-library-ac6884
https://github.com/juanespj/PSoC_Neopixel
Good luck with your project.
BiBi_1928986
Level 7
Level 7
Hello.
