Here is another display component, this time for OLEDs using the WS0010 controller in 4-bit parallel mode. I tried to make it a drop-in replacement to the stock character LCD component, it should be pretty easy to use.
These modules are gorgeous! Really sharp with great viewing angles and available in various colors. I included a photo below of the module running with a PSoC5LP prototyping kit.
The component is available at my Github repository over here. I included a 'datasheet' with the component with info on how to use it, you can also check this blog post for more info.
JobinT_31
25 likes received 10 likes received 5 likes given
Hello Thanasis,
Thank you for sharing this in Cypress Community.
Jobin
You are welcome! I plan on making a couple more display components if I can find where I've hidden all my modules 🙂
