Hi all,
Has anyone tried to use the CMSIS-RTOS v2 API wrapper from Arm in a PSoC Creator project? I am developing for a PSoC 6 using the CYBLE-416045-02. If so, how did you configure the project to get it to work?
A wrapper can be found here: GitHub - ARM-software/CMSIS-FreeRTOS: FreeRTOS adaptation for CMSIS-RTOS Version 2. It is designed to be a CMSIS pack for use with Keil uVision, but I am wondering how I can adapt it for use with PSoC Creator without exporting my PSoC Creator project to uVision and developing there.
Thank you in advance!
Hello MiDu_3979751,
I tried including the CMSIS-RTOS v2 API wrapper from the Github link that you provided and was able to create a crude project with 2 threads.
I have attached the project. Can you please check and let me know if this works for you?
Thanks and Regards,
Rakshith M B
Rakshith M B
Hello MiDu_3979751,
Thanks and Regards,
Rakshith M B
Rakshith M B
