RaAl_264636
Level 6
Level 6
50 sign-ins 25 sign-ins 10 solutions authored
has anyone succesfully used C++ on PSoC? I want to use a C++ source code. On the first run I want to know if it will fit into a 5LP. I switched to the latest ARM GCC release (9-2020-q2). I replaced the GCC exe file with the G++ exe file.
There was an issue in CyLib.c with the initialization of the SysTick Callbacks regarding the void* 0 pointer. Replacing it with "nullptr" resolved the issue. Now, it seems(!) that it can be linked. As expected, it won't fit into the device on the first run, the error message is:
Build error: <...>/xyz.elf section `.ARM.exidx' will not fit in region `rom'
The bad thing is that the .elf file is deleted directly after the build process - it can be seen shortly in file explorer. Trying to copy it while it exists results in a empty file, unfortunately. I assume the created file is filled with valuable content for checking how much the flash content is in size. Too bad that the output window doesn't show the size in this configuration.
There's also an error "cm3gcc.ld:91: undefined symbol `RomVectors' referenced in expression". I don't know if this is related to the error mentioned above.
So, I've two questions:
1) how to get the information regarding the build size / prevent that the .elf file is deleted
2) how to check what's going on with those RomVectors?
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I answered I have.
But please note that C++ is not supported by PSoC Creator, so what we are doing is hacking
and not guaranteed nor recommended.
And I also can not guarantee nor recommend it (at least for the time being).
Having written above, you know, I tried my hack using CY8CKIT-059 😉
schematic
pins
animal.h
#ifndef _ANIMAL_H_
#define _ANIMAL_H_
extern "C" {
#include "project.h"
#include "stdio.h"
class animal {
public:
    animal(char *name) ;
    ~animal() ;
    void move(int x, int y) ;
    void go(int x, int y) ;
private:
    char *_name ;
    int _x ;
    int _y ;
#endif /* _ANIMAL_H_ */
animal.cpp
extern "C" {
#include <stdio.h>
#include <string.h>
#include "main.h"
#include "animal.h"
animal::animal(char *name)
    _name = new char[strlen(name) + 1] ;
    strcpy(_name, name) ;
    _x = 0 ;
    _y = 0 ;
animal::~animal(void)
    delete [] _name ;
    _x = 0 ;
    _y = 0 ;
void animal::move(int x, int y)
    _x += x ;
    _y += y ;
    snprintf(str, STR_LEN, "%s moved to %d %d\n",_name, _x, _y) ;
    print(str) ;
void animal::go(int x, int y)
    _x = x ;
    _y = y ;
    print(str) ;
main.h
#ifndef _MAIN_H_
#define _MAIN_H_
extern "C" {
extern char str[] ;
extern void print(char *str) ;
#define STR_LEN 64
void *operator new(size_t size) ;
void  operator delete(void *ptr) ;
void *operator new[] (size_t size) ;
void  operator delete[] (void *ptr) ;
#endif /* _MAIN_H_ */
main.cpp
extern "C" {
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "animal.h"
#include "main.h"
char str[STR_LEN+1] ;
    UART_PutString(str) ;
void init_hardware(void)
    CyGlobalIntEnable; /* Enable global interrupts. */
    UART_Start() ;
    animal *cat ;
    init_hardware() ;
    print("\x1b[2J\x1b[;H") ;
    print("PSoC 5LP C++ Test (Experimental) ") ;
    snprintf(str, STR_LEN, "(%s %s)\n", __DATE__,__TIME__) ;
    print(str) ;
    cat = new animal("mikan") ;
    cat->move(3, 3) ;
    cat->move(3, 3) ;
    cat->go(2, 4) ;
    for(;;) {
    return malloc(size) ;
    free(ptr) ;
    free(ptr) ;
Tera Term Log
So the good news is at least my c++ program could be compiled and my cat can walk a little.
The bad news is that there is no one who will guarantee nor support for further exploration.
moto
MotooTanaka
Level 9
Level 9
I once tried the following URL with PSoC 4 and it worked.
Your mileage may vary for PSoC 5LP.
https://blog.mbedded.ninja/programming/microcontrollers/psoc/using-cplusplus-with-psoc-creator/
moto
MoTa_728816​ I know the URL, sorry that I didn't mentioned it. In fact, I think that I've done it as the blog describes. Interestingly, I had not to do most of the things mentioned there regarding undefined references, etc., but the current setup was only switching to the newest GCC build and using G++ instead of GCC, as mentioned in the URL under #13. So, I'm not using any C++ code, just the default code of an empty PSoC project (and the SysTick tweak mentioned). And this results in the error mentioned above.
So, I'd be glad if you can help me to dig deeper into it to check where the error is.
MotooTanaka
Level 9
Level 9
Right now I'm only writing off my head, I have not tried it by myself.
I wonder if ".map" file remains or not.
If ".map" file is left, you can see the rom map.
Meantime, about the symbol problem, from my (old) experience,
I think that  c functions must be protected by using the "extern "C" { }"
moto
MoTa_728816
I'll check for the map file. Regarding the protection, it means that I've to protect all C files which are automatically generated? I thought that the GCC/G++ automatically detects the "source" type depending on the file extension.
MotooTanaka
Level 9
Level 9
Since C++ allows multiple functions in the same name, the compiler expands the function name with its parameter signature.
So, *.c will be fine, but *.h may need to be protected.
IMHO, you don't have to modify the "Auto Generated" files, but something like below should work
In the source file which could be compiled by c++
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
For the details, please "google" "extern c", "c++"
moto
MoTa_728816​ Okay, I'll keep that in mind.
But, if the auto-generated files don't have to be modified, why the empty project fails?
MotooTanaka
Level 9
Level 9
I assumed that ".c" files are compiled with "gcc" or "cc"
and ".cpp" or ".C" files are compiled with "g++" or "c++".
If ".c" files are also to be compiled with "g++" or "c++"
then I think that we need "extern C {" in "*.c" files, but modifying auto generated files are usually not recommended.
moto
MoTa_728816​ As far as I know PSoC Creator is fixed to GCC, because it's hard-coded. That's why the blog post item #13 replaces the GCC.exe with the G++.exe.
MotooTanaka
Level 9
Level 9
I answered I have.
schematic
pins
animal.h
#ifndef _ANIMAL_H_
#define _ANIMAL_H_
extern "C" {
#include "stdio.h"
class animal {
public:
    ~animal() ;
private:
    char *_name ;
    int _x ;
    int _y ;
animal.cpp
extern "C" {
#include <stdio.h>
#include <string.h>
#include "main.h"
#include "animal.h"
    _x = 0 ;
    _y = 0 ;
    delete [] _name ;
    _x = 0 ;
    _y = 0 ;
    _x += x ;
    _y += y ;
    print(str) ;
    _x = x ;
    _y = y ;
    print(str) ;
main.h
#ifndef _MAIN_H_
#define _MAIN_H_
extern "C" {
extern char str[] ;
#define STR_LEN 64
main.cpp
extern "C" {
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "animal.h"
#include "main.h"
    UART_Start() ;
    animal *cat ;
    init_hardware() ;
    print(str) ;
    cat->move(3, 3) ;
    cat->move(3, 3) ;
    cat->go(2, 4) ;
    for(;;) {
    free(ptr) ;
    free(ptr) ;
Tera Term Log
moto
MoTa_728816​ Thank you for creating the 5LP project. I compared it to my attempts, and it seems the 'no exception flag' was causing the missing romvector symbol... Strange... Since it was mentioned in the blog with a different error message, I didn't think of that this might be the issue.
Now I have a base to build on. I know that there's no official support, but maybe this topic might help others to get into it. Too bad that Cypress doesn't implement C++ for PSoC.
EDIT: I was too early... the missing romvector symbol is still present if I try to modify my test project according to your reference project... I'll keep this topic updated about it.
