DaSi_281136
25 replies posted 10 replies posted 5 replies posted
 I had a working project where I decided to change out a control register which I've done many times in the past.
For some reason I now get an "undefined reference" error when I try to write to it.
I've tried to clean and rebuild but no luck.
I've also defined the UDB as individial lines and as a bus but I get the same result.
Any ideas?
DaSi_281136
 I figured it out.
The Demux component was being optimized out because I was using a "logic 0" component to drive its input.
Once I swapped out the logic 0 component for a control register it started working.
DaSi_281136
I'm not sure but it looks like the control reg component is being optimized out.
When I open Control_Reg_1.c all of the functions are greyed out.
DaSi_281136
 I figured it out.
Bob_Marlowe
Level 10
Level 10
Yes, the optimizing process does a pretty good job...
Bob
ETRO_SSN583
Level 9
Level 9
Actually it has finite limitations.
For example if trying to implement gate delays, or a chain of NOTs to
build an osc it will eliminate them. Clearly does not know what you intentioned.
Like a traffic cop at an intersection and you are trying to speed thru because
your femoral artery is ripped. Sometimes the best of intentions create the worst
possible results.
Regards, Dana.
Bob_Marlowe
Level 10
Level 10
Dana, you make me shudder!!! Hoping that you never made such experiences!!!
Bob
ETRO_SSN583
Level 9
Level 9
Be not afraid.
DaSi_281136
I dind't realize there was so much drama attached to PSOC development!
