- Email to a Friend
I've just downloaded the PSoC Creator 4.4 and I'm trying to build an exisiting project. However, I can't do it as PSoC Creator can't update it's components to the required versions:
My project needs cy_boot to be version 6.10, but only 6.0 is available. Also, it need cy_isr to be 1.71, but only 1.70 is available.
According to Help -> Update Manager, everything is up to date:
Here is some information about my environment, installed products etc, Help -> About:
Environment:
PSoC Creator 4.4 (4.4.0.80)
Culture: English (United States)
OS Version: Microsoft Windows NT 10.0.19043.0
CLR Version: 4.0.30319.42000
Installed CyInstaller Products:
Peripheral Driver Library 3.1.1
Peripheral Driver Library 3.1.3
Peripheral Driver Library 3.1.5
PSoC Programmer 3.29.1
PSoC Creator 4.4
Loaded Plugins:
Version: 4.4.0.80
Company: Cypress Semiconductor
Description: Loads component customizers.
Name: Addin Discovery
Version: 4.4.0.80
Description: Discovers PSoC Creator addins (kits, language packs, etc)
Version: 4.4.0.80
Description: Device Catalog Plugin
Version: 4.4.0.80
Description: Adds the topics available in the documentation.
Version: 4.4.0.80
Description: Adds a start page to the framework.
Name: Output Window Plugin
Version: 4.4.0.80
Description: Adds the output window
Version: 4.4.0.80
Description: The Source Code Control Manager is the central class used for SCC actions within PSoC Creator.
Name: Symbol, Schematic and SchMacro Factory
Version: 4.4.0.80
Description: The Symbol and Schematic Factory is used to load, cache, and retrieve symbols and schematics.
Name: Project Manager Plugin
Version: 4.4.0.80
Description: Adds project management related functionality.
Version: 4.4.0.80
Description: Loads the Symbol and Schematic editors
Version: 4.4.0.80
Description: Supports user files in multiple languages
Version: 4.4.0.80
Description: The Workspace Factory is used to retrieve instances of PSoC Creator workspaces.
Version: 4.4.0.80
Description: The Project Factory is used to retrieve instances of PSoC Creator projects.
Version: 4.4.0.80
Description: PSoC Creator Toolchain Manager
Name: ARM GCC Generic
Version: 4.4.0.80
Description: ARM GNU Generic
Name: ARM MDK Generic
Version: 4.4.0.80
Description: ARM MDK Generic
Name: ARM IAR Generic
Version: 4.4.0.80
Description: ARM IAR Generic
Name: DP8051 Keil Generic
Version: 4.4.0.80
Description: DP8051 Keil Generic
Version: 4.4.0.80
Description: Adds a dialog that allows the user to select a device.
Name: File Editor Factory Plugin
Version: 4.4.0.80
Description: Add file editors to the framework.
Name: Transport Framework
Version: 4.4.0.80
Description: Provides a generic device communication framework for use by other plugins.
Version: 4.4.0.80
Description: The Core Debugger provides an architecture independent framework for the common debug features.
Version: 4.4.0.80
Description: Provides debugging support for the different PSoC families through a GDB back end.
Version: 4.4.0.80
Description: Provides debugging support for FM device families
Name: Device IO Transport
Version: 4.4.0.80
Description: Provides device IO support for Cypress devices though PSoC Programmer APIs.
Name: Serial Transport
Version: 4.4.0.80
Description: Provides basic serial device support for the rest of the tool.
Version: 4.4.0.80
Description: Provides a host tool to perform bootloading operations.
Name: Background Elaborator
Version: 4.4.0.80
Description: PSoC Creator Background Elaborator.
Version: 4.4.0.80
Description: The TypeCache Factory is used to retrieve instances of TypeCaches.
Version: 4.4.0.80
Description: PSoC Fitter Plugin
Version: 4.4.0.80
Description: FM Fitter Plugin
Version: 4.4.0.80
Description: Registers resource editors with devices.
Version: 4.4.0.80
Description: Enables quick and correct development of applications that use DMA.
Version: 4.4.0.80
Description: Manages custom component tuner executables
Version: 4.4.0.80
Description: The Notice Window displays notices (status messages / errors with managed lifetimes).
I've already tried a lot of things to solve this problem. Probably the only thing I didn't do is to reinstall the OS 🙂
I have a feeling that PSoC Creator is not able to download these required components from some remote server(s). This guess is also supported by what I found in the PSoC Creator logs (C:\Users\<user>\AppData\Local\Temp\PSoC Creator-000.log):
Unable to download latest online manifest: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
It should also be mentioned that this problem is observed for different computers located on different networks. That is why I think the problem is related to some server, and not to the computer.
- Email to a Friend
Hello @Ant0n ,
The components you have indicated have higher version numbers, than the version which is available for updating. Can you try by equalizing the version numbers to the one available for update?
I did try downgrading versions and updating versions, and the component updater seems to be executing the tasks correctly. Hence, I do not suspect this could be a problem with the update server. I have attached a copy of the log to this post. I suspect firewall or anti-virus configuration may cause this issue. I will try to get further details and update you.
Sampath Selvaraj
- Email to a Friend
Hello @SampathS_11,
Thank you so much for your reply!
Unfortunately I can't do it. The project I'm trying to build requires these components (cy_boot, cy_isr) to have specific versions (6.10 and 1.71 accordingly). Of course I could try to use components of different versions, but it could break something in the project.
I also know for sure that components I'm looking for do exist (cy_boot_v6_10 and cy_isr_v1_71) the problem is just PSoC Creator can't download/use them.
Are you sure that in this case the PSoC Creator really downloaded something from the server? Could it be that during this "downgrading versions and updating versions" process PSoC Creator was just using local files that were downloaded previously, let's say at a time when the server was still running? Please note that in my case I am dealing with a freshly installed PSoC Creator that probably has not had time to download local files yet.
- Email to a Friend
I am having exactly the same problem. Fresh install of 4.4. Colleague created a project on another machine and it uses 6.10 and 1.71, which I cannot get or update to. Suspect it is a recent problem
- Email to a Friend
I have just received a certificate error on the site - expired July 8th 2022. Anything to do with it?
- Email to a Friend
Hi @Ant0n,
We have forwarded your query to our internal team, who will evaluate your query.
We will provide a response as soon as we get an update from our internal team.
Thank you for your patience.
Thanks and Regards,
Gautami J
- Email to a Friend
Hello @Ant0n ,
I have the same problem. We tried to reinstall and update psoc Creator , but nothing to do.
I wish they solve as soon as possible this problem.
- Email to a Friend
Until the expired *.cypress.com certificate is renewed you can do what I did.
Change your computers date from July to June.
Update the components.
Change the computers date back to July.
It worked for me.
- Email to a Friend
Thanks Bob! It worked!
