I'm experiencing a problem editing datapath instructions in the UDB editor.  In the Compare Options section of the Configure Instruction dialog box, Option 1 has two choices: Config A and Config B.  Every time I try to choose Config B it accepts my choice.  However, if I try to re-edit the instruction, I find that Option 1 has reverted back to Config A.  This happens every time.
Has anyone else had this problem?  Am I missing something?
JobinT_31
25 likes received 10 likes received 5 likes given
Hi Paul.
Which PSoC Creator version you are seeing this issue. The issue is partially resolved in the latest PSoC Creator 4.1. You can see the generated verilog code is changed to selected setting  "`CS_CMP_SEL_CFGB," correctly. This will be completely fixed in our future release.
Jobin
JobinT_31
Hi Paul.
Jobin
Hi Jobin,
Thanks for the confirming the bug.  I'm using PSoC Creator 3.3.  I can't use version 4.1 because I'm running Windoze XP.  Hopefully, I can get a new work computer in the near future, but for now I'm stuck with this one.
Paul
