When I generate .hex file with PSoc Creator and I load it with PSoc Programmer I have the following error message :
"Debug mode enabled, this should be turned off from PSoC Creator before production"
How can I turn off debug mode to produce correct .hex file ?
My project is for PSoc 5 (CY8C5588LTI-114) and I program with JTAG.
Thanks in advance
go to project tab and select build settings, near the top it says configuration, change it from debug to release
I have done it, I take file \ARM_GCC_441\Release\my_project.hex.
When I want to load this file with PSoc programmer I have always the same error message.
Go to CYDWR --> System TAB --> Program/Debugging --> Check "Enable Device Protection".
Rebuild your project and program your Hex file.
Please let me know if it worked for you now.
SRIM
It has work.
Thanks a lot
