ETRO_SSN583
Level 9
Level 9
Here is a DDS approach another poster turned me on to, very fascinating.
Think State Variable, second order, 2 integrators + sign change = oscillator. Or think
second order IIR with positive feedback.
Runs just from C code, 80 uS ( 12.5 Khz ), 40 samples/sine.
With optimization, conversion to fixed point, binary size elements, ASM vs C, or HW solution,
should yield much higher freq.
Add a timer to control code placed in ISR, eg.  sample period, or just use a delay function to control sample rate.
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
Forgot to include this reference -
www.ee.ic.ac.uk/pcheung/teaching/ee3_Study_Project/Sinewave%20Generation(708).pdf
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
The other way of tuning the DDS is of course keeping poles on unit circle.
Regards, Dana.
 Interesting approach
Hi Dana
This is great idea many thanks.
I´m testing it tuning frequency with ISR and working fine !
Is possible making with similar method Karplus Strong synthesis ?
Kamil
ETRO_SSN583
Level 9
Level 9
I would think so. One could take the transfer function, and factor the
sinusoidal component from the rise/decay element transfer function.
Or implement the transfer function directly in IIR form. Looks like an
even simpler function from inspection.
ETRO_SSN583
Level 9
Level 9
A couple of references. Note the Stanford f(t) just looks like a damped sine,
so seems like straightforward cascade of sine generator and exponential decay
block.
music.columbia.edu/cmc/musicandcomputers/chapter4/04_09.php
ccrma.stanford.edu/~jos/lab_inst/lab_inst.pdf
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
I have not yet tried this but seems if you recompute the coefficients of the
diff eqn. for binary  value, like 32 or 64 (samples/sine, sample rate), might
get tighter code loop, eg. higher frequency out of the design. Food for thought.
Regards, Dana.
Many thanks interesting references.
Kamil
Hi Dana
I´m implementing simple component from your great IIR filter sine idea.
Kamil
My simple questions - is possible make this IIR sine with DFB component ? (respective karplus strong DFB ?)
Thanks info Kamil
ETRO_SSN583
Level 9
Level 9
Certainly Verilog. I would assume, because of simplicity of IIR
architecture DFB would also work, At the moment I do not have
time to do this, but would bet much >> frequency generated would
be result, and of course easier tunability.
The real investigation would be to look at integer math solution that keeps
poles on unit circle while being tuned. That should result in highest performance.
Regards, Dana.
Hi Dana
Many thanks info
Kamil
