        Just upgraded to PSoC Designer 5 SP 6. When I compile and click on errors listed in the output from Build screen, Designer no longer jumps to the file and line of code containing the error.
Just re-installed 5.5 and it works as expected
Using WIN XP Pro
        Hi Poppe,
May I know which compiler you are using? I believe you are using HiTech. Is it right?
Sachin
