what is the difference between SDA_SetDriveMode(SDA_DM_DIG_HIZ) and SDA_write(high) or what is the use of  void Pin_SetDriveMode (uint8 mode)
AnkitaS_51
<pin_name>_Write: Writes the value to the Component pins.
<pin_name>_SetDriveMode : Sets the drive mode for each of the Component‘s pins.
I suppose "SDA" is the name of Pin Component in this case.
http://www.cypress.com/file/45381/download
AnkitaS_51
