Creator 2.0 features many new components, the S/PDIF Transmitter is one of those.
It is supported by DMA, offers 8/16 and 24-bit sample length and supports up to 192 kHz sample rate. Streaming music from your PSoC has just become a lot simpler.
Hint: Datasheets for all components can be opened directly within Creator. If you select the component, a preview window shows a link to the datasheet underneath the component list.
