Registration Issue
ShLa_2252246
I can not seem to register PSoc creator 4.2 due to our company Proxy server settings. I continue to get
"Network or registration server error"
I know PSoc creator works fine but having the nag screen to register every time I launch the program is annoying. Is there a registry key I can change to prevent this window from being displayed on startup?
DheerajK_81
You can disable the registration window by using the check box as shown below:
Note that, if you cancel the registration process or if the network was unreachable after three attempts, the dialog will display a checkbox that allows you to never register the product and this window will no longer be displayed.
Dheeraj
DheerajK_81
Dheeraj
NazarP_56
25 solutions authored 10 sign-ins 50 replies posted
Also, if you see Keil registration dialog (not clean from description), so you can disable it in Tool->Options...
Nazar
