Dear all:
I am very happy to see cypress provide us the source code for the free software (PSoC creator and designer)! but i am very confused about the source code!
And if i can use the Sharp Zip Lib under the VS2010 environment, or i can transfer the c# source code to .lib file by using VS2010, after that i can use the PSoC creator's API lib in VS2010!
Attached website:http: //www.cypress.com/?rID=38310
Thanks for you kindly reply!
markgsaunders
50 sign-ins 10 solutions authored 5 solutions authored
Hello!
Please note that we only supply the source code for the open source packages used in PSoC Creator and Designer. We do not supply a full source base for either product.
-- mgs
OK! and i konw, thanks for you reply!
So we cannot use VS2010 calling for the API in PSoC creator
