Hello everyone, I need help because I am currently doing a PLC system with a data transmission in SMBus (a Slave module and a master module). Unfortunately, I can't find a module on PSoC designer allowing me to manage this communication protocol. I found an example with a SMBus Slave, but it is not compatible with my microcontroller. So my questions are:
- Is it possible to use SMBus modules with a CY8CPLC20-48LTXI?
- If so, are there any examples that I can take back knowing that I am not very strong in programming?
Thank you in advance for your response.
SMBusSlave User Module cannot be used with the PLT User Module, since the resource requirements of both the User Modules will not fit on a PSoC1 device.
Sampath Selvaraj
Sampath Selvaraj
