I am trying to program my CY8C4248LQI-BL583 and CY8C21334-24PVXI with CY8CKIT-002 with same software. I can program CY8C4248LQI-BL583 with PSoC Programmer 3.26 and CY8C21334-24PVXI with 3.13. While I cannot use same software's different versions in the same PC, I cannot program both of these with same software. Is there any possibility to program CY8C21334-24PVXI with PSoC Programmer 3.26 or adding libraries (source files) of this product to software? Because I could not find the device family on 3.26.
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
To get to view the CY8C21334 on PSoC Programmer 3.26, do the following steps:
- Set AutoDetection to Off in the Programming Parameters box
- Select Protocol ISSP from the Programmer Characteristics box
- Select 21x34 in the Device Family selector
- You will find CY8C21334-24PVXI in the Device selector.
SampathS_11
Thank you so much. Worked pretty well !!
