03:45 PM
When trying to work with my CY3212 development board I am having problem opening an example project. I am using PSoC Designer 4.4 and the most recent example projects downloaded from Cypress. When I open a project I get the following error message:
"The specified part is not loaded in the device library.
Status 0xc00426c0
Subsystem: PSoC Device Editor Engine"
It looks that Designer has the appropriate user modules for the device present in the development board, since I can create a project from scratch and select the proper device and the CSR user module that it needs to use the CapSense features.
But I really would like to be able to open the example projects to study them and use as a learning help. Any help will be welcome. Thanks.
Status 0xc00426c0
08:35 PM
Problem solved, it was a directory setup problem with my Windows installation.
07:08 PM
I was looking at someone else's project and kept seeing this error every time I loaded the project. I didn't realize that PSoC Desiger projects look for a file called PSoCConfig.xml by default. If a file by that name isn't present in your project folder, you'll see "The specified part is not loaded in the device library" upon trying to open a project.
In my case I didn't realize that this xml was given a bunch of aliases in my project folder. I was expected to rename the xml file I wanted to use, to get the associated project to load properly.
