Hi
I have a project based on PSoC Creator 3.3 and I want to export it to KEIL MDKv5
But as soon as "Next" button is clicked in IDE Export Wizard an error window pops up with message :
"Unhandled exception has occured in a component in your application. If you click continue, the application will ignore this error and attempt to continue.
Value can not be numm.
Parameter name: path 1"
So after clicking the "Continue" nothing happens and just the error window closes.
I can not see any export of project.
Is this a known problem ?
Can someone please provide some inputs ?
Hi Sankalp,
There is a known issue in importing a projects to uVision version 5.16 to 5.20. Please check the uVision version and use a different one.
JOBIN GT
Welcome in the forum, sankalp.
I would suggest you to get in contact with Cypress directly: At top of this page select "Design support -> Create a Support Case" and ask your question. You will be helped by a Cypress engineer.
Bob
PS: Where in Germany are you located? I live near Bremen.
Thanks Bob
I am in Munich
Hi Sankalp,
JOBIN GT
