Power Toggle Switch
 Hi Everyone,
I'm fairly new to the PSoC creator. I'm working with the PSoC 5LP develeopment kit. Attached to this message is my project I am working on to use a switch to turn on a LED but to also use that same switch to turn off the LED and turn on another after holding that LED for 4 seconds. I set up a design that I'm most confident will work, with a debouncer to a counter.
The issue I am having is with the main.c that I am building. If I use the debouncer sperately I can toggle the LED on and off with the switch easily, but with the counter connected I seem to lose this capability. Also i cannot seem to get the other LED to turn on after 4 seconds. PLS HELP.
ETRO_SSN583
Level 9
Level 9
If you are trying to post your project do NOT use Google Chrome,
seems that it is a problem on this website. Use Firefox or IE.
Regards, Dana.
