On Creator 4.0 (4.0.0.432), in the Pins resource page, when I try to select a pin to assign a port the pull-down menu closes on me automatically, so I cannot select the pin.
I checked the keyboard/mouse is Ok.
No other applications are showing the problem.
Here is a short movie showing the issue -- https://vimeo.com/192566258
Perhaps related, upon opening the project, the status line on the bottom right shows a blinking "Ln 1 Col 1 INS" as if it being continuously updated.
Any clues what this is all about?
Thanks for any help!
Close all the unnecessary tabs on which you are not working in PC4.0.
"Ln 1 Col 1 INS" blinking because the code is stuck at a certain line no. in certain opened file in a tab.
I suggest you to check if any key or button is stuck on Keyboard or mouse.
Meanwhile,you can provide us with your project to see if this is any generic issue with PC4.0
I resolved this issue by going to the PSoC exe file properties and setting the "Compatibility" to "Windows 8".
