JaOr_4642046
First like received
Hi to everyone,
I am new with this Chip, I am trying follow the video tutorial,  "PSoC 6 101: Lesson 1-4 FreeRTOS",  to figure out how to play out with it.
in this video I can see something like (image), used to configured the FreeRTOS, among other things.
  As I said, I am trying to run this, but I can´t because I don´t have "Peripheral driver library" as it is shown in the video.  In my case I get:
( below I attached a capture of my IDE )
I runned the "cypress update manager" with this result
And I configure the Library 3.1.1 and 3.1.2, with the same negative result.
If some of you could help me about this....
Thank you very much in advance
Rakshith
Hi JaOr_4642046​,
Can you please let me know the device that you are using? PDL is supported by only PSoC 6 devices.
So I think you are using a different device. If you do have a PSoC 6 device with you, please select the right PSoC 6 device in the Device Selector.
You can access the Device Selector by right clicking on the project in the Workspace Explorer and selecting Device Selector as shown - pastedImage_0.png
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi JaOr_4642046​,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Thanks for your answer Rakshith
I have been reading about this in: https://www.cypress.com/file/410246/download
I had the hope there was another way to set this configuration, (for follow the video tutorial).
I am using: CY8C5868AXI-LP035 (=PSoc 5) and CYBLE-212020-01 (= PSoc 4), also I am using the CY8CKIT-042-BLE with the module CY8C4247LQI-BL483
so apparently I can´t use this characteristic, do I?.
In this case,  could you help me with how can start/get with easy examples with freeRTOS and BLE? for these Chips
Thanks for your help and time.
Thanks and Regards,
JaOr
Hi JaOr_4642046​,
Yes, unfortunately there is no PDL support for PSoC 4 and PSoC 5 devices at the moment.
1. For PSoC 4 devices you can follow this blog - https://iotexpert.com/2017/02/23/psoc4-freertos-port/
2. For PSoC 5 devices you can refer to the links in this thread - freertos
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Many Thanks
