I've just installed PSoc Creater 4.1 on Windows 10, and It's throwing a bunch of errors on startup. (like in this post https://community.cypress.com/message/141236.
Details Errors:
Error fmk.M0018
An important piece of PSoC Creator has a problem and may not work correctly. Please restart PSoC Creator.
Unable to initialize system dependencies. Could not find a part of the path 'C:\Program Files (x86)\Cypress\PSoC Creator\4.1\PSoC Creator\dev\cyprjmgmtsearchpath.xml'.
Log file for this session is located at: C:\Users\peter\AppData\Local\Temp\PSoC Creator-000.log
Error: fmk.M0018: An important piece of PSoC Creator has a problem and may not work correctly. Please restart PSoC Creator.
System.NullReferenceException: Object reference not set to an instance of an object.
   at CyDesigner.Common.Db.DeviceDb.Catalog.CyDcDeviceLoader.LoadCatalog(CyAbsPath devDataPath, String xmlRelativePath, String xmlSchemaRelativePath)
   at CyDesigner.Common.Db.DeviceDb.Catalog.CyDcPlugin.PostPluginsLoadedInit()
   at CyDesigner.Framework.CyPlugin.CallPostPluginsLoadedInits(IEnumerable`1 directory, Boolean printPluginLoadTimes, IDictionary`2 pluginLoadTimes)
Error: prj.M0274: Unable to initialize system dependencies. Could not find a part of the path 'C:\Program Files (x86)\Cypress\PSoC Creator\4.1\PSoC Creator\dev\cyprjmgmtsearchpath.xml'.
   at CyDesigner.Common.Db.CyS3Db.CyBGElaborator.PostPluginsLoadedInit()
   at CyDesigner.Device.FitterPSoC.CyFitterPSoCPlugin.PostPluginsLoadedInit()
   at CyDesigner.Device.FitterFM.CyFitterFmPlugin.PostPluginsLoadedInit()
An help is appreciated!
Update: I tried downgrading to 4.0 and it works fine. Maybe something is wrong with 4.1 or my download was corrupted (I tried twice using Akami with the same errors)
