RyYo_1406951
Please tell me how to change (set) the link order of the source code.
To change(set) the link order, should create a "Custom Linker Script"?
Re-confirmed this inquiry again.
Unfortunately, there is no feature to change Link order in PSoC creator.
One solution would be to export a project from PsoC creator to Makefile and change the link order in makefile manually.
TakashiM_61
1000 replies posted 500 solutions authored 750 replies posted
Still need to do double check for this question, but there seems to be no interface / GUI to change the link order in PSoC Creator.
BTW, you mentioned "Custom Linker Script". Does it means LD file (File extension is .ld)?
→Please continue to check for Question.
→Yes.It points to the following Build Settings.
→Is the usage of Makefile out of Cypress Support?
 (because GNU)
Why would you like to change the link order? is there any problem with current link order in PSoC creator?
And since the Makefile is more general (i.e. not Cypress specific product), we would encourage you to modify it by yourself first.
→I would like to change the link order and see if can reduce the ROM capacity.
(※ With other tools, the link order has been changed and the ROM capacity has been reduced.)
→There is no problem now.
thank you for your clarification.
if you will encounter any issue, please feel free to post a thread in CDC.
Thank you for your support.
