Hi all,
We develop PSoC code under Winows using PSoC Creator. However, all of our build test servers run under Linux.
Ideally, we would like to use our test servers to run automated tests of all changes to firmware. I know that running PSoC Creator under Linux isn't easy, but is it possible to perform a build under Linux from the command line?
Hugo
PSoC Creator Software
PSoC Creator can only be built using Windows platform. You need to run a virtual machine running Windows on Linux and then you can perform builds using command line. The commands can be found here: Building PSoC® Creator™ Projects Using Commands - KBA88205
These commands can also be run on any automation testing tools like Jenkins etc.
Dheeraj
Dheeraj
