Attempting to program the PSoC 5LP from the CY8CKIT-059 with the device programmer and PSoC Programmer program through the 5 pin SWD option. The program does detect the correct device CY8C5888LTI-LP097 but when the programming function is selected, it errors saying the the hex file doesn't match the detected device. If I program the part inside PSoC Creator 4.2, it does work. A secondary problem is that if I select +5V, a warning pops up that says the part will be damaged but I select 'Continue' anyway. Not sure what to do to use the programmer and would like to figure it out for the sake of manufacturing.
Nick
PSoC Community Components
Are you quite sure you do not attempt to program the PSoC5 residing on the snap-off Kitprog?
Bob
