02:25 PM
May 18, 2011
02:25 PM
I've tried installing PSoC Designer 5.1 SP 1.1 and it gets stuck at this point for hours until I give up and cancel. I have done a complete uninstall of PSoC Designer 5.0 and of the aborted 5.1 install, restarted, and still no luck.
The box is running Windows Vista Business x64.
Anybody else had trouble installing this version? Perhaps I should give up and go back to 5.0?
12:18 AM
May 19, 2011
12:18 AM
please file a support case and our support team will help you with the installation.
http://www.cypress.com/go/support and then in the lower right hand corner "Crteate a case"
The problem you are seeing is very likely tied to your personal setup and you specific computer.
Let our Cypress Support Team work with you directly, we will get you through this issue
Robert
