marvian_s
Hi
I am using the last version of PSoC Creator 4.4  with CY8CKIT-050  and I could not use a timer or counter. I saw PSoC 101 but the timer and counter dose do not have enough control pin for PSoC 5l in PSoC Creator. I study the timer and counter and still couldn't figure. Would you guide me where can I found some examples like pdf, book, or video? My new company uses PSoC 5L and I want to catch it as soon as possible.
Marvian
VenkataD_41
Hi Marvian,
Have you gone through the Timer code example for PSoC 5LP in PSoC Creator? If not, please go through it once. I have attached it with this email.
The timers in PSoC 5LP can be either Fixed Function components or Universal Digital Block (UDB) based components.
For more information about the Timer APIs and how to use them, please refer the Timer component datasheet. (attached that also)
For more  code examples please refer the following web page.
https://www.cypress.com/documentation/code-examples/psoc-345-code-examples
Thanks and regards
Ganesh
VenkataD_41
Hi Marvian,
Thanks and regards
Ganesh
Len_CONSULTRON
Level 9
Level 9
500 solutions authored 1000 replies posted 750 replies posted
Marvian,
To locate a working example of timer-based project perform the following steps:
  1. Select "Find Code Example..." in the "Start Page" tab.
  2. Enter "PSoC 5LP" in the "Device family:" field  and "Timer" in the "Filter by:" field.
  3. You can then select a project from the list like "Timer" and then select "Create Project" button.
Len
