PSoC Creator parallel build
JaSi_1632926
Level 4
Level 4
Welcome! 25 replies posted 10 replies posted
Building with PSoC Creator is painfully slow. I have disabled Windows Defender and such (no other antivirus stuff going on). When observing the Windows Task Manager during building, I can see that PSoC Creator seems to utilize only one core. Sure, the hardware mapping stuff is probably a NP-complete problem, but building with GCC is a standard thing to do in parallel (make -jX anyone?).
How can I make PSoC Creator to at least compile in parallel?
I'm using PSoC Creator 4.2 on Windows 7.
Thanks, Jacob
HeLi_263931
Level 8
Level 8
100 solutions authored 50 solutions authored 25 solutions authored
You can add own flags in the build configuration. But I doubt that you can do that for make, I think its only for gcc. When running from Creator AFAIK its not based on make.
Yeah, I tried adding flags for the compiler but that didn't work. It needs to be added on a higher level somehow.
